Take the bearing out and contact berry bearing, they are nationwide or contact telsta
If the race or outer ring is intact there is a number on it and any bearing company can cross reference it even if it is a OEM Bearing
They designed it to use after market materials, even if telsta tells you that you have to get it from them, they got it from a bearing supplier like Timken or TRW
Hell you might even get it from Graingers, they have the largest selection of industial bearings.
I got a rotate worm gear, bushings and shims for a stelco boom for $200.00 from Graingers when Stelco said only their parts would work and they wanted $1700.00 for the rebuild parts.
Re: Parts help
